ElecTech Posted July 29, 2017 Posted July 29, 2017 Been called to a new site where issues are being had with a fire alarm which has had XP95 sounder beacons installed 2 years ago into a blast freezer/chiller area. The area gets down to -38c. The sounders are starting to go into fault & the spec says -20c I think. Anyone know of any XP95 sounder beacons that can withstand the low temp OR a solution with some sort of enclosure which can keep them ambient temp but the sound not affected. There around roughly 10/15 sounders in there but are apart of a 120 device loop. Quote
Shaunb1905 Posted July 29, 2017 Posted July 29, 2017 I'm sure they're is a conventional sounder capable, so just stick a sounder controller on the loop (psi needed) and good to go Quote
james.wilson Posted July 29, 2017 Posted July 29, 2017 -38 is proper cold, I reakon that is specialist area. What do you use other than kit designed for minus 20? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
ElecTech Posted July 30, 2017 Author Posted July 30, 2017 Yeah it is specialist, its almost like a blast freezer, I don't believe staff are in there when it goes down to those levels but regardless the sounders will need to be present when they are inside at say -20c. 11 hours ago, Shaunb1905 said: I'm sure they're is a conventional sounder capable, so just stick a sounder controller on the loop (psi needed) and good to go Yeah I'm sure that would work but cant find the sounder capable. What's a PSI by the way? Having not been to site I'm interested to how its wired as just been checking the FP200 spec & that's only rated down to -20c. I will update once I know more. Quote
Shaunb1905 Posted July 30, 2017 Posted July 30, 2017 1 minute ago, ElecTech said: Yeah it is specialist, its almost like a blast freezer, I don't believe staff are in there when it goes down to those levels but regardless the sounders will need to be present when they are inside at say -20c. Yeah I'm sure that would work but cant find the sounder capable. What's a PSI by the way? Having not been to site I'm interested to how its wired as just been checking the FP200 spec & that's only rated down to -20c. I will update once I know more. I meant PSU sorry Quote
ElecTech Posted July 30, 2017 Author Posted July 30, 2017 2 minutes ago, Shaunb1905 said: I meant PSU sorry Ah ok, yeah understood nice one. Quote
ElecTech Posted July 30, 2017 Author Posted July 30, 2017 Iv found a beacon that goes down to -50c Would a beacon solely be sufficient without the sound? Is there regulations to say sound has to be primary and a flashing beacon as a secondary visual? Quote
