13 minutes ago, al-yeti said:
Ok but if you don't want perimeter protection by the way of shocks etc how will be youbdetect a brick before it breaks your windows
Shutter would be good , with the necessary detectors on it
Easy init
See previous response vis a vis shutters. Council no allow shutters. They think shutters lower the tone of the area. They're not the ones who have to clean up the mess of course.
Is the cafe in the city centre ?
27 minutes ago, MrHappy said:
In addition to being an alarm monkey I was once a shutter monkey....
I could have been a c# monkey, but I had more self respect ...
You can see why I don't find this stuff challenging can't you? How are things in Southfield Road? Or are you in St Mary's?
I'm 138miles away ;)
Posted (edited)
deffo 138ml from your post code ;)
I assumed you meant "southfield" in Liverpool,  if your going off the ISP "south field" locally is 9.1ml away
Being a simple connector of wires.... what you using dropbear for ?
Edited by MrHappy
If it is so simple why are you talking about wiring normally closed detectors in parallel or dualtechs for detecting bricks?
My question was because your initial few posts seemed like you were a sparky who had bitten off more than you can chew on a clients job.
Happy bodging.
  • Upvote 4
2 hours ago, al-yeti said:
Come on be serious , no one can do jack , you install a system they take no contract and don't have it attached to insurance etc
However if the cafe owner took a discount from there insurer gets done over when they ask for the cert etc they simply won't pay out
So you don't bother with efficacy insurance then?
Posted (edited)
50 Southfield Rd, xxxxx xxxxx. Right? IP address 5.xxx.xxx.xxx
It's amazing what you can reveal about yourself by a single click of a mouse button.
Edited by MrHappy
  • Downvote 4
20 minutes ago, RayPooley said:
135 according to Google Maps.
Ok how about beams in addition to something else
Is your wallet as big as your filing cabinet with certs you hold
Seriously beams and something else
Brick proof glass would do it but expensive
If I did then?
But that's the point , if your installing graded and maintaining it , you can get in trouble
