Part set Enforcer?
Hi all,
I'm having trouble part setting my Pyronix Enforcer panel from the user code.
When setting the alarm with the user code, it allows me to set Zone A only. It won't let me set Zone B.
If I set from the engineer menu, I can select either Zone A or B.
I have flexi set enabled for the user.
Anybody know where I'm going wrong?
Thanks in advance.
Link to comment
Share on other sites
Not sure , but do you have to enable zones to part set , so if the attributes are not set then there's nothing to set
From engineering is that some kind of forced set
Just keeping you occupied until an expert arrives
  • Like 1
Link to comment
13 minutes ago, Simlec said:
Do you mean areas A, B, C or D and your user code only allows you to set A?
If so you need to enable set/unset area B for that user code.
Excellent Mr Barnes
Link to comment
I did wonder this, but is this an option on the enforcer? If so, how? I can't see anything in the manual, and when I went into 'Codes and Users' in the engineer menu, I saw no option for doing this.
I'm wondering if I'm trying to do the wrong thing? I've set a 'part set' as Zone B and then when I want to only 'part set' (i.e at night), I want to be able to select Zone B when I put my user code in. Is this right?
Link to comment
12 hours ago, Simlec said:
Enter master user menus (press D then enter your master user code)
You can then change user areas under change codes menu
Hi,
Thanks for your reply.
I tried this but nothing happened. The 'A' button remained illuminated and it wouldn't allow me to select 'B'.
It's version 10.
Thanks in advance.
Link to comment
