fatman Posted August 17, 2017 Posted August 17, 2017 Hi all, I'm having trouble part setting my Pyronix Enforcer panel from the user code. When setting the alarm with the user code, it allows me to set Zone A only. It won't let me set Zone B. If I set from the engineer menu, I can select either Zone A or B. I have flexi set enabled for the user. Anybody know where I'm going wrong? Thanks in advance. Quote
al-yeti Posted August 17, 2017 Posted August 17, 2017 Not sure , but do you have to enable zones to part set , so if the attributes are not set then there's nothing to set From engineering is that some kind of forced set Just keeping you occupied until an expert arrives 1 Quote
datadiffusion Posted August 17, 2017 Posted August 17, 2017 (edited) As above. Lovely weather? Edited August 17, 2017 by datadiffusion 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Simlec Posted August 17, 2017 Posted August 17, 2017 Do you mean areas A, B, C or D and your user code only allows you to set A? If so you need to enable set/unset area B for that user code. 1 Quote
al-yeti Posted August 17, 2017 Posted August 17, 2017 13 minutes ago, Simlec said: Do you mean areas A, B, C or D and your user code only allows you to set A? If so you need to enable set/unset area B for that user code. Excellent Mr Barnes Quote
fatman Posted August 17, 2017 Author Posted August 17, 2017 29 minutes ago, Simlec said: Do you mean areas A, B, C or D and your user code only allows you to set A? If so you need to enable set/unset area B for that user code. I did wonder this, but is this an option on the enforcer? If so, how? I can't see anything in the manual, and when I went into 'Codes and Users' in the engineer menu, I saw no option for doing this. I'm wondering if I'm trying to do the wrong thing? I've set a 'part set' as Zone B and then when I want to only 'part set' (i.e at night), I want to be able to select Zone B when I put my user code in. Is this right? Quote
Simlec Posted August 17, 2017 Posted August 17, 2017 (edited) Enter master user menus (press D then enter your master user code) You can then change user areas under change codes menu Edited August 17, 2017 by Simlec Quote
fatman Posted August 18, 2017 Author Posted August 18, 2017 12 hours ago, Simlec said: Enter master user menus (press D then enter your master user code) You can then change user areas under change codes menu Hi, Thanks for your reply. I tried this but nothing happened. The 'A' button remained illuminated and it wouldn't allow me to select 'B'. It's version 10. Thanks in advance. Quote
