  On 18/08/2017 at 07:19, Amps said:
Have you enabled the keypad for area B?
Expand
No I don't think so. Do I have to do this even though I'm not using an RKP?
I don't recall seeing this option but I'll have a look when I'm home from work.
Expand
Thought he wants to part set?
Or is part setting done via areas on the enforcer ?
I find a lot of people esp. domestics using a slightly more commercial panel, often choose Areas to try and achieve what most of us would just use Part for.
  • Like 1
  • Upvote 1
Expand
I think this is what I'm doing (or trying to do).
I couldn't actually find the designated 'Part Set' option, and having the PIR's respond differently in different zones was the only way I could think of getting the same effect.
Unless I missed the part set option?
Expand
I fixed an enforcer once , he asked me about part set , his part set was like setting full set and panel was upstairs so never got round to finding out why the B key doesn't part set
I still don't get it lol
Expand
Lol! As long as I'm not the only one! ;)
Expand
An Enforcer part set is Area B.  Go to Assign Keypads/Readers -> Keypad 00 and assign Area B to it.
  • Like 1
Expand
Hi there,
Thanks for your reply. I went here and it was already assigned to all zones. However, I set it to A and B, but this hasn't worked :-(
Is Area B assigned to the user code?
I think you are presuming that both the A & B keys will be highlighted when you enter your code. This is not always the case.
Enter your code and the A key is highlighted. If you press the B key is that highlighted?
  • Like 1
Expand
Thanks for the quick reply.
Yes Area B is assigned to the user code.
If I enter the code, A is highlighted only. If I try to select B, A remains highlighted but B still doesn't come on.
