fatman Posted August 19, 2017 Author Posted August 19, 2017 No idea what the problem is. I've checked inputs are assigned to the Zones in question, I've enabled flexi set, I've done everything that I can possibly think of, plus the advice given on this thread. I've initiated a clean start, still no fix. I can only assume that there's some kind of fault with the system until Pyronix get back to me. Thanks for all the advice so far. Will update when I hear back from Pyronix. Any other suggestions more than welcome in the meantime ;-) Quote
Amps Posted August 19, 2017 Posted August 19, 2017 Only other thing i can think of and not sure if it will make any difference. Do you have a final exit zone for area B? 1 Quote
al-yeti Posted August 19, 2017 Posted August 19, 2017 2 minutes ago, Amps said: Only other thing i can think of and not sure if it will make any difference. Do you have a final exit zone for area B? Thought b was part set , or is this like the scanny abcd Quote
fatman Posted August 19, 2017 Author Posted August 19, 2017 1 hour ago, Amps said: Only other thing i can think of and not sure if it will make any difference. Do you have a final exit zone for area B? Yes, it has a final exit. I even tried changing this to entry/exit route just to see if it made a difference, but still didn't. 1 hour ago, al-yeti said: Thought b was part set , or is this like the scanny abcd Yes B is part set, although it has no inputs assigned to it at first so it has to be done manually. Quote
Simlec Posted August 19, 2017 Posted August 19, 2017 Have you enabled flex set for that user? You have to enable flex set globally and then for each user. im not sure if it's needed as I always have one set, but you may need a zone setting as FX or ER You also need zones assigned to area A & B to uses areas A & B ! 1 Quote
fatman Posted August 19, 2017 Author Posted August 19, 2017 2 hours ago, Simlec said: Have you enabled flex set for that user? You have to enable flex set globally and then for each user. im not sure if it's needed as I always have one set, but you may need a zone setting as FX or ER You also need zones assigned to area A & B to uses areas A & B ! This was the problem! I thought 'Flexi Set' was a global option only, and whatever you set it as using the Engineer Code would be a global thing, but apparently not. Thanks for this, and thanks to everyone else on the thread for taking the time to help me with this issue, your experience and expertise has been greatly appreciated. Quote
Amps Posted August 19, 2017 Posted August 19, 2017 On 17/08/2017 at 12:27, fatman said: I have flexi set enabled for the user. You mean in System Options flexi set was turned off? Im sure the default is flexi set on. Did you turn it off? Glad you got it sorted. 1 Quote
fatman Posted August 19, 2017 Author Posted August 19, 2017 23 minutes ago, Amps said: You mean in System Options flexi set was turned off? Im sure the default is flexi set on. Did you turn it off? Glad you got it sorted. I think the main problem is that I was inputting the master manager code instead of the user code (which wasn't set), but once I added a user, set user parameters for zones A and B, it worked. But don't tell anyone that I was that stupid ;-) Quote
datadiffusion Posted August 19, 2017 Posted August 19, 2017 4 hours ago, fatman said: But don't tell anyone that I was that stupid ;-) You're fine, we only get just over a million hits a month at TSI 1 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
