fatman Posted August 18, 2017 Posted August 18, 2017 Slightly disappointed with the Comfort LED's on the Deltabell W-E. Very dim and irregular flashing. I understand this is probably to conserve batteries, but I'd have thought it could be overridden by supplying power to the Bellbox. Oh well. Small price to pay, I suppose. Quote
al-yeti Posted August 18, 2017 Posted August 18, 2017 52 minutes ago, fatman said: Slightly disappointed with the Comfort LED's on the Deltabell W-E. Very dim and irregular flashing. I understand this is probably to conserve batteries, but I'd have thought it could be overridden by supplying power to the Bellbox. Oh well. Small price to pay, I suppose. Fit the X in SCB mode with lamp If it's with a mini panel of sorts 1 Quote
fatman Posted August 18, 2017 Author Posted August 18, 2017 1 hour ago, al-yeti said: Fit the X in SCB mode with lamp If it's with a mini panel of sorts I have an illuminating Bellbox on the front. Do you think I'd get away with another on the system, or would that be too much? Quote
al-yeti Posted August 18, 2017 Posted August 18, 2017 6 minutes ago, fatman said: I have an illuminating Bellbox on the front. Do you think I'd get away with another on the system, or would that be too much? What model is it in? I think SCB mode you would but you could stick a wireless as additional on the enforcer rear of property of other is on front But charging current would do two I think in SCB mode 1 Quote
fatman Posted August 18, 2017 Author Posted August 18, 2017 (edited) 5 minutes ago, al-yeti said: What model is it in? I think SCB mode you would but you could stick a wireless as additional on the enforcer rear of property of other is on front But charging current would do two I think in SCB mode Front is SCB. Rear is just set up as standard Wireless Bell, but with the addition of running power to it for the Comfort LED's. (I thought this would make the Comfort LED's function better, but it appears I was mistaken lol) Edited August 18, 2017 by fatman Missed punctuation Quote
al-yeti Posted August 18, 2017 Posted August 18, 2017 1 hour ago, fatman said: Front is SCB. Rear is just set up as standard Wireless Bell, but with the addition of running power to it for the Comfort LED's. (I thought this would make the Comfort LED's function better, but it appears I was mistaken lol) I assume wireless was part of kit Quote
fatman Posted August 18, 2017 Author Posted August 18, 2017 19 minutes ago, al-yeti said: I assume wireless was part of kit Yes this came with the kit Quote
