cableing under floor
Guest jamie
Now thats where the skill part comes into effect :)
30082[/snapback]
I think that should be luck. ;) All the new-builds I've worked in you'd never work out where the pipes were after the ceilings and floors were in unless you had just drilled through it!
30094[/snapback]
Been there Done that, using the same technique, managed to cut through a high pressure council boiler fed pipe :(
not for the faint hearted, your a braver man than me Dave.
Regards
Bellman
I can honestly say I have never ever even browsed a pipe in what must be 200+ installs done this way. My secret being a thin 6"" screwdriver to gently push through and probe around underneath with. I know this isnt the fastest way but done without time being an issue you`d never know I was there. :)
30100[/snapback]
Knowing my luck i'd push it into a cable and electrocute myself :unsure:
Regards
Bellman
30100[/snapback]
Guess what's going to happen tomorrow then! :whistle:
No way, im just tooo carefull.
30112[/snapback]
Never say Never Dave...
Regards
Bellman
I like Daves up and over methed, never thought of that before. Would be no worries if you had a stud/pipe detector?
I used to take a good few hours planning jobs where chip board has been used, theres always a way if you think about changing where you were going to put your equipment.
Service Engineer
My opinions may not reflect those of my employer, managers, colleagues, customers, friends, family or pet rabbit.
Guest Dave the alarm man
Lift flooring ????? in a House?????
You crazy fools
My firm just tacks & goes :D
if have a sqeaky floor a dab of talc does wonders & uses up those christmas stocks of brut / old spice :D
