G2-44 and IR800 PIRs
cjdavi34
8 minutes ago, cjdavi34 said:
Thanks all for your help, I've done as al-yeti suggested and it all seems fine so far. One other question, the newer rf portal I have has more jumpers on it than the older version. Does it make much difference if the protocol on the portal is set to (a1+a2)or (a1+v2). I can't find any info that explains what the difference is nor can I find out much about the sensors
Picture? I haven't seen that one
Mr galaxy will may some thing soon?
Link to comment
Share on other sites
I'm not sure where Alpha 2 is used. The jumpers are correct. Peripherals should be configured for Alpha where possible, as it has better supervison.  To conserve battery life, the detectors will back-off from reporting every event when constant motion is detected.
Link to comment
