Posted (edited)
Hi guys I hope you are all well. I was wondering what the best dual tec pet tolerant pir is? I have a scantronic 9600 with 3 door contacts and 4 pirs (aritech ev125p) you may be familiar with them, they have proved to be very reliable over the years rarely ever had a false alarm if any. Until! we get a dog, well a chorkie, its kind of a mix between a yorkie and chihuahua, non the less  an annoying hyper ankle biter:D:angry:. The issue is whenever someone passes the house or rings the doorbell while we are away the dog would jump on the couch near the window and go mental this triggers the lounge pir and sets off the alarm, It has got the the point where I have to omit the lounge and  upstairs hall pir. This gets pretty irritating after a while, I would like the whole house to be armed and not parts of it.
So what I am after is a very reliable pet tolerant pir, dual tec preferably. I have had a look at the risco i wise and bosch blueline, I read that they will ignore any animal up to 40lbs but does that mean they will still ignore the dog even when it jumps on the couch? what are your experiences? Do you know of any better pet pirs? If it were up to me i would just lock it in a room but the missus like to give it the freedom to roam around the house:rolleyes:
Any help would be appreciated, thanks
Edited by CR Alarms
Blue line is probably what the dudes will recommend but can you install any shocks on the windows or does dog headbutt door?
Why not just omit ,on a newer panel this would all be easier to do , reality you need to scrap that panel even if you think it's good
Posted (edited)
Hi, ideally yes I should probably scrap the panel  but it still works and its not broken so why replace it? The issue is we now have a dog and it gets irritating having to mess around with the keypad switching off certain zones before setting the system. Before I would just enter the pin select group A then leave, happy days, but now I have to mess around with the omit setting.  I will give the bosch blue line a go but will it ignore the dog jumping on the couch thats the question? if not I guess I will just have to lock it in a room upstairs regardless what the missus say.Wiring shock sensors is not an option I'm afraid even if I wanted to (tiled floor, finished walls ect, it will be messy)  thanks for the help.
Edited by CR Alarms
Posted (edited)
al yeti, I have no intention on replacing a fully working system,however If it ever does die i will take your suggestion, but for the moment my question is will the blue line completely ignore the dog regardless if it jumps on the couch? I believe its says it on its spec will ignore any animal below 40lbs. its just a small dog we are talking about here and weighs a stone (14lbs) at best.
thanks
Edited by CR Alarms
Posted (edited)
Beg your pardon al yeti, misread your last post, Is the pyronix wireless add on thing something which I can connect to my 9600 which enables me to add wireless devices such as shock sensors ect? thanks
Edited by CR Alarms
On a spare zone yes, only issue will be it will act as a single zone with multiple detectors
thanks for that, do you happen to have the exact name for this device? One more thing from your experience, will the blue line pet pir (45lbs) completely ignore the dog regardless if it jumps on the couch or will it likely still trip it? ta
2 hours ago, al-yeti said:
I don't have experience with blue line
Pete where you at man
https://www.pyronix.co.uk/products-and-solutions/ur2-we
Worth doing for a diyer
Only a Complete Retard would recommend Pet Pyronix sensors in an environment.
