Hi Im just upgrading an old system with lots of shock contacts on the system and replacing with a euro 46 app panel having trouble with panel saying input/area mismatch, 1st time using the panel and looking through the manual cant see any reference to this, also im doubling up on zones 2 shocks at most as wiring is looped in areas so no other choice its a while since i used resistors should it be 4k7 at 1st contact then 4k7 2k2 at end contact
Yep as above it always threw me why people though you could 'chain' EOL then found out that gal supports it!
14 minutes ago, sixwheeledbeast said:
Texecom also support multiple shunts up to three devices.
Oh right, have only fitted a handful of Prem's and didn't know that! A couple have double doors but I just did one door per zone.
