So I'm just playing with my alarm to get head round it have so far fitted bell box, front door contact and hall PIR.
 Question is when I go to set the alarm I walk to the panel in the hall I have to walk past the PIR. I  go to set the alarm but can't as the PIR is active I have to wait 10 or so seconds for the PIR to deactivate then I can set it. Is that right ? I have read the instructions but can't see anywhere about it.
Anyone any ideas the alarm works fine or once set the PIR will set the alarm off if moving in front of it and have set the final edit as the front door and that works fine.
Any ideas ?
Thanks
Mark
no,
I asssume it need to be "entry route" rather than intuder
2 minutes ago, Mark Rider said:
Ar ok I have set the PIR as an intruder. Will try it as an entry route but will that delay the alarm on entry if it was a burglary
Thanks
any open zone which is not "Final exit" or "Entry Route" at the time of setting will cause exit fault
When Set an "Entry Route" zone allows you (or the burglar) to walk arcoss that sensor when in the alarm  is in "Entry"
If the alarm is set & not in entry it creates an alarm
I'm guessing your IT? why on earth are you pissing about with an alarm...
I can understand if want to wire if the property is "difficult" or under "renovation"
but 2nd fixing what you describe is at most a  morning work ?
Posted (edited)
1 hour ago, Mark Rider said:
IT ? Nope why do you think that ???
guess / insult
I'm totally renovating my bungalow so each room I do I'm wiring the alarm in to that room
I'm not seen it, but unless its f'kin massive a true bungalow is pish easy
Edited by MrHappy
  • Like 1
I didnt say it wasn't easy should take a day to do it in one go as the cabling is peace of cake but as you say whats point in doing the job twice may as well wait until I'm in the room that I'm doing then run the cable.
