Yeager147 Posted September 17, 2017 Posted September 17, 2017 Hi all, I joined this forum as i recently installed a Pyronix Enforcer+ system in my house, and thought i would be a good idea to be linked with people, professional or otherwise with more knowledge about alarm systems than myself. I do have an opening question to all about my self installation. I have a single beep from the control panel every minute or so which is intermittent throughout the day. Does anyone have any ideas what could be causing this, regards Jamie. Quote
al-yeti Posted September 17, 2017 Posted September 17, 2017 Panel been installed a year? Is it a service timer? Quote
Yeager147 Posted September 17, 2017 Author Posted September 17, 2017 It's been live for 6 months with no problems so far. Friday night it started beeping for about 2hrs. Sat nothing and started again this afternoon. Forgive my ignorance but what is a service timer?... Quote
MrHappy Posted September 17, 2017 Posted September 17, 2017 35 minutes ago, al-yeti said: Panel been installed a year? Is it a service timer? shows "service required on the display" after 367 days the beep is either something "chiming" or fault which should be visable when entering a code Quote Mr Veritas God
Yeager147 Posted September 17, 2017 Author Posted September 17, 2017 I've tried to fault find as best i could, run through diagnostics menu to check batteries and signal strength as it's a wireless system and all seems good, however i will have to consult the manual a bit more. Unfortunately i have this beep every minute and it's driving me mad. I don't know if i should power down the system, remove all batteries. Quote
MrHappy Posted September 17, 2017 Posted September 17, 2017 does a small "c" show in the bottom rh line of the lcd ? Quote Mr Veritas God
Yeager147 Posted September 17, 2017 Author Posted September 17, 2017 I'm not sure, not at home right now but will post a reply shortly, cheers... Quote
Yeager147 Posted September 17, 2017 Author Posted September 17, 2017 No small "c" on the rhs of lcd guys... Quote
petercts Posted September 17, 2017 Posted September 17, 2017 hi silly question do you have a standalone battery powered smoke detector you would be amazed how many times we have all been on a callout only to find its the smoke alarm battery going flat Quote
al-yeti Posted September 17, 2017 Posted September 17, 2017 1 hour ago, petercts said: hi silly question do you have a standalone battery powered smoke detector you would be amazed how many times we have all been on a callout only to find its the smoke alarm battery going flat Lol forgot about that classic ,.good reminder Quote
