frenchman Posted September 19, 2017 Posted September 19, 2017 Learned the w/less sab on a texecom 64w kit, wait until all data is collected and all showing ok but no response when the bell test is activated. Tried deleted and relearning, same result. Any ideas? Quote
AdrianMealing Posted September 19, 2017 Posted September 19, 2017 How are you testing it? Quote amealing@texe.com Head of Industry Affairs Visit Our Website Texecom
frenchman Posted September 20, 2017 Author Posted September 20, 2017 Engineer utility, then do bell test then yes Quote
AdrianMealing Posted September 20, 2017 Posted September 20, 2017 OK, does the bell show in Ricochet monitor? What does the wiring type say for the zone that the bell is assigned too? Quote amealing@texe.com Head of Industry Affairs Visit Our Website Texecom
frenchman Posted September 21, 2017 Author Posted September 21, 2017 Yes it did. Seems to be ok once the data collecting is done and then going in day mode and back in. Quote
AdrianMealing Posted September 21, 2017 Posted September 21, 2017 So it works now yes? Quote amealing@texe.com Head of Industry Affairs Visit Our Website Texecom
frenchman Posted September 22, 2017 Author Posted September 22, 2017 Yep, the ricochet learning process seems a bit hit and miss though Quote
AdrianMealing Posted September 22, 2017 Posted September 22, 2017 How far away were you from the panel when you learned the bell. Need to learn everything on close to receiver, then go and put everything up in its location starting with closest to the panel first. The bell is no different to anything else with regards learning so not sure why you had the issue. Quote amealing@texe.com Head of Industry Affairs Visit Our Website Texecom
frenchman Posted September 26, 2017 Author Posted September 26, 2017 Thanks for the tip, done a couple more since and all seems ok now. 1 Quote
