I'v never done "service" as a job role nor does our company hold any intruder maintenance contracts... Can someone confirm the steps to what's required as a bare minimum when doing a PPM.
Im thinking...
Walk test every device
Sample test some tampers depending on the size of install
Sample test resistance on devices again depending on the size of install
Battery calcs (batt volt, current in alarm, current in standby, batt charging volt)
all signals to ARC inc comms fail both paths?
Set/unset where possible
Bell test, test bell tamp, remove power
Check no rearms, entry timers, exit timers, bell duration, reset levels
Compare as fitted install to specification
Fill out maintenance log...
I'm unsure so add, correct or remove anything to help...
Im thinking...
Hmmm looking at records from time to time , a third of that list is charged about £60 , and not allot of that is done
Posted (edited)
Im thinking...
Sample test some tampers depending on the size of install - will cause more problems than it solves.
all signals to ARC inc comms fail both paths? - don't touch that Dualcom Ariel it will eventually break!
Bell test, test bell tamp, remove power  - test bell tamp will cause more problems than it solves.  in a perfect world it should be tested though
Edited by Amps
