Alarm Problem
Guest advent750
Guest advent750
The transformer has two 12v tappings, how much voltage can be put into the board and what is the required amount. I thought the 12v with a high va would be ok.
I think that doubling the tappings to get 24Vac could probably blow the regulator, because after rectifying & smoothing it`ll be nearer 36VDC into the regulator.
There aren`t many regulator`s that will tolerate that voltage input.
Best bet is to replace it with an 18VAC TX of simillar rating.
30792[/snapback]
The manual specifies 18Vac. i don't like to see them much over 20Vac on any panel. 24Vac (across both tappings) may be ok, but, I think the panel struggling with under or over voltage will cause problems in the end.
If you don't know......ask.
30793[/snapback]
ditto
Guest advent750
Ok I will try and get an 18v transformer and change that. One more thing can anyone recommend anything to fit at the end of the driveway which is approx 100yds from the house to indicate when anything comes onto the drive. Prefer a wireless option at the moment.
Guest advent750
What size of battery would you recommend fitting. I was only replacing what was originally there, as fitted by a Professional company.
I dont see the problem in fitting a 7AH battery with this panel, its charging circuit can easilly cope with it. We fit 7AH batteries as standard in most panels we fit.
Also the cost of the battery and TX would still be less than the price of most companies callouts, and his time is free so no charge for that.
Ok I agree that most engineers wouldn`t have changed the TX in the 1st place, so that was a needless cost.
Pete, most if not all endstations are capable of 7ah.
I agree the likes of 9448+ etc can only handle 2.1 ah but the books clearly state the panels capacity of each one, some now up to 17ah.
Paul
PG Security Systems
Somerset
SSAIB Certificate of Merit Installers.
www.pgsecurity.co.uk
I was under the impression that the new EN regs will mean that we will all have to fit bigger batteries to accomodate the required longer standby times hence the reason why panel boxes have got bigger while the pcbs get smaller.
Mark Hawks
Ex BT Openreach Field Service
