al-yeti Posted August 24, 2019 Posted August 24, 2019 1 hour ago, james.wilson said: As 6wb to lower risk to prevent doors being left open as well as detection Need grade 3 then , I seen doors left ajar where contact just comes within range to set lol but I guess still protected Quote
Eugene's DIY Den Posted August 24, 2019 Author Posted August 24, 2019 6 hours ago, aechlin said: Why do you need 22 contacts anyway? You only need to put them on external entries/exits, let the PIR's do their job. Alistair Just belt-and-braces. Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
Eugene's DIY Den Posted August 24, 2019 Author Posted August 24, 2019 I notice since I installed my new SW 10-70 panel, I haven't had any false alarms. Separate tampers for each zone, so the sum of series resistances is less (11 sensors plus junction boxes, bell box, keypads etc). Maybe the immunity against transients spikes and bad connections due to tarnished tamper connections in junction boxes is better? Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
datadiffusion Posted August 24, 2019 Posted August 24, 2019 True story this, today after 3 years in storage we wheeled out our (new at the time) Bosch dishwasher and said goodbye to the crappy built-in one that came with the house. To my annoyance, it went into error 5 minutes after every cycle, even though it had been cleaned and drained before we moved. What was it? The flow switch uses an externally mounted reed over a sealed into the main water jacket rotating wheel with magnet. Jammed shut. Mild percussion maintainance fixed the machine Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
sixwheeledbeast Posted August 25, 2019 Posted August 25, 2019 Mild percussion maintenance, speak reit posh down thaa. Quote
datadiffusion Posted August 25, 2019 Posted August 25, 2019 Don't worry we've got 2 whippets and an outside toilet so you wouldn't feel too left out! Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
norman Posted August 25, 2019 Posted August 25, 2019 26 minutes ago, datadiffusion said: Don't worry we've got 2 whippets and an outside toilet so you wouldn't feel too left out! Tha moved t' Barnsley, pop rand I'll get't pan on t'ob forra brew. Quote Nothing is foolproof to a sufficiently talented fool.
al-yeti Posted August 25, 2019 Posted August 25, 2019 11 hours ago, Eugene's DIY Den said: I notice since I installed my new SW 10-70 panel, I haven't had any false alarms. Separate tampers for each zone, so the sum of series resistances is less (11 sensors plus junction boxes, bell box, keypads etc). Maybe the immunity against transients spikes and bad connections due to tarnished tamper connections in junction boxes is better? What firmware is on panel? Quote
Eugene's DIY Den Posted August 25, 2019 Author Posted August 25, 2019 4 hours ago, al-yeti said: What firmware is on panel? Not sure, it's two years old. Why do you ask? Quote Talking Tools, a Facebook group for discussing anything tool/DIY related.
al-yeti Posted August 25, 2019 Posted August 25, 2019 49 minutes ago, Eugene's DIY Den said: Not sure, it's two years old. Why do you ask? Just wondering how you update it , your in Ireland yes? Updates allow you to use some new devices that come out and fix any issues , although mostly I only needed to update for devices , firmware seems stable otherwise Quote
