Moataz Posted October 19, 2017 Author Posted October 19, 2017 No no I didn't plugged in the key , am just asking if I can reprogramme it with the key or not, the pcb was working good and the anti drill sensor was connecting to it and I left it working for 15 hours then the problem happened and I don know what happened Quote
GalaxyGuy Posted October 19, 2017 Posted October 19, 2017 4 minutes ago, Moataz said: @Galaxy Guy I had to go for replacment because the led go.straight to on at power up , but I have what is called programming key that connected direct to the PCB , can this work for reprogramming the PCB I'm not sure what you mean. Can you post an image or link of the 'programming key' you are talking about ? I haven't seen a programming key for the Flex. I did see an SPI key offered on SecurityWarehouse, but not sure where that plugs in, as there's no socket apart from USB. I had just assumed that it was a mistake on SW. Quote
Moataz Posted October 19, 2017 Author Posted October 19, 2017 Yes I mean the spi key , and I checked the panel rightnow , there is no place to plug in and I don know why it comes with the order if it is useless, or may there is a way to connect it to the panel idk. Quote
GalaxyGuy Posted October 19, 2017 Posted October 19, 2017 I think it must be a part number mistake, as there's no mention of any SPI bus on the Flex in any documentation. Some PCB's have the SD slot populated, but it hasn't been carried in the design. There's no low level firmware recovery option for standard users. Your problem may even be hardware. Quote
Moataz Posted October 23, 2017 Author Posted October 23, 2017 @Galaxy Guy do you have an idea how to get software application for galaxy flex coz I am trying to upgrade the software through flash programmer app may be that will solve the problem. Quote
GalaxyGuy Posted October 23, 2017 Posted October 23, 2017 Honeywell only provide firmware to installers. Quote
Moataz Posted October 25, 2017 Author Posted October 25, 2017 What you mean by installers , installers who fit the intrution system or what.coz what I am doing now that I am trying to install the panel and the sensors on site so am I called installer ? Quote
Moataz Posted October 25, 2017 Author Posted October 25, 2017 One more thing @Galaxy Guy I have sc100 antidrill sensor and the tamper sensor work correctly but it is not detecting the vibration so can you provide me with the correct way of connecting sc100 to galaxy flex fx050 panel Quote
Moataz Posted October 25, 2017 Author Posted October 25, 2017 And fyi ,What I have on the antidrill sensor RTi,RST,T1,T2,NO,C,NC,-,+ and on the panel Z,0V,12V what I am done I removed jumpers 19 "tamper and alarm" and connected resistor between T1 and T2 and resistor between NC, C then I connected NC with 1kohm eol to z1 and T2 with eol 1kohm to z2 and t1 and c on the 0v on the panel Quote
al-yeti Posted October 25, 2017 Posted October 25, 2017 1 hour ago, Moataz said: One more thing @Galaxy Guy I have sc100 antidrill sensor and the tamper sensor work correctly but it is not detecting the vibration so can you provide me with the correct way of connecting sc100 to galaxy flex fx050 panel Thought you said the sensor was working 1 hour ago, Moataz said: And fyi ,What I have on the antidrill sensor RTi,RST,T1,T2,NO,C,NC,-,+ and on the panel Z,0V,12V what I am done I removed jumpers 19 "tamper and alarm" and connected resistor between T1 and T2 and resistor between NC, C then I connected NC with 1kohm eol to z1 and T2 with eol 1kohm to z2 and t1 and c on the 0v on the panel If panel doesn't work how do you know that sensor not working or is panel now working? Quote
