Moataz Posted October 26, 2017 Author Posted October 26, 2017 @Galaxy Guyy @al-yeti Okay after tomorrow I will reconnect the sensor to the panel as galaxy guy recommended and I will share pictures with you coz I finished my work for today and tomorrow is my weekend , thx for your support. Quote
MrHappy Posted October 26, 2017 Posted October 26, 2017 10 hours ago, Moataz said: welcome back OX! 1 1 Quote Mr Veritas God
GalaxyGuy Posted October 26, 2017 Posted October 26, 2017 3 hours ago, al-yeti said: Dude what you on about He's got the role jumpers still in and using resistors , unless I confused , but if not you need to start again Instructions far to messy I hadn't seen the jumpers when I seen this on my phone - sorry. They are wrong anyway. The second jumper block is set to pins 5+6 and should be 1+2. When using the built-in EOL resistors: At the panel: +12v to brown. 0v at the zone to blue. The zone input to green. At the sensor, connect: Brown to +12v Blue to 0v. Now loop a wire from 0v in the sensor and connect it to NC. Connect the green wire to T2. The instructions are in English and made sense to me. Quote
Nova-Security Posted October 29, 2017 Posted October 29, 2017 needs a jumper on J19 as term 8 is current set to not used Needs minimum a 6 core but wiring in cat 5 Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
al-yeti Posted October 29, 2017 Posted October 29, 2017 1 hour ago, Nova-Security said: needs a jumper on J19 as term 8 is current set to not used Needs minimum a 6 core but wiring in cat 5 Intruder alarms not a big thing in middle east (as you can imagine......) Hence working with what your given Quote
