Ashton Posted October 22, 2017 Author Posted October 22, 2017 Just found it 24.200ghz miles out 1 Quote
Ashton Posted October 22, 2017 Author Posted October 22, 2017 Alarm relay does seem to open on masking everything else opens the trouble relay but that's not in use according to manual Quote
Ashton Posted October 22, 2017 Author Posted October 22, 2017 I'm thinking relocate opposite corner and recable see how it goes sound reasonable? Quote
sjsturner Posted October 22, 2017 Posted October 22, 2017 So you have changed the detector? you have swapped the cores used inside the cable? You have swapped the zone used ie from main panel to node. and you still get the same result? is it going Alarm or is it Tamper when it activates? i would strongly suggest it is environmental or could be a cable issue still, when you swapped cores around how did you do it? swap Alarm pair for tamper pair? Or did you have an 8 core there? Quote
Ashton Posted October 22, 2017 Author Posted October 22, 2017 Hi yes I've changed from a circuit in the panel to a circuit on An expander I've changed the detector and I've changed cores multiple times to all different colour combinations 8 core (using two cores as on resistors) and is going into Alarm condition Quote
sjsturner Posted October 22, 2017 Posted October 22, 2017 How strange, to satisfy curiosity In this situation I would swap the detector with one from a different room just to make sure, as you know the others don't false alarm. i would also look at why the suppressor is there and how bad is the ac leakage. when it was on the node was it the first zone? Quote
Ashton Posted October 22, 2017 Author Posted October 22, 2017 Hi I put the surpressor on when I fitted it votages were all ok I put it on as a prevention for the future and yes is very strange never had something as perculiar before Quote
datadiffusion Posted October 22, 2017 Posted October 22, 2017 ^ What he said. One at a time and 'faulty' detector should either be swapped (or go on standalone test rig to soak etc...) Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Ashton Posted October 22, 2017 Author Posted October 22, 2017 all I will give all a shot and post back with remedy Quote
