Sounder fault - after breakin
Guest Guest_Mark_*
Guest Guest_Mark_*
Hi went in to re-set a Menvier panel after a breakin only to find the internal sounder is kaput. Apparently is was working the night before, no signs of physical damage to the panel, perfromed a factory re-set but not beepy noises.
Anyone seen this before?
Ive had the speaker output blow a couple of times on ts700's
Yup me too, menviers have a habit of having problems with the speaker output, have seen a couple where the speaker output doesnt work for a couple of seconds.
Mark Hawks
Ex BT Openreach Field Service
Really..? I`ve never come across that problem. I dont install many Menviers ATM, but that will change soon enough :)
Yup ive had at least two with said problem, not recently i hasten to add but then we dont use menvier anymore, switched to a panel not stuck in the past.
Mark Hawks
