AParsons Posted October 30, 2017 Posted October 30, 2017 Have got a Galaxy 500 with G500 v1.25 UK firmware. The PCB says B0077 Rev 1.6 with the 0 struck out. The PROM also has F028-01-125-P1 on it. Anyone got a later PROM or know of an upgrade path? The alarm was as good as gold for nearly 20 years then developed a battery charging fault - rest of the alarm still worked perfectly. The alarm company said it was hardware fault and we would have to have new panel. A new panel, a Galaxy Dimension 48C was fitted and within about 9 months it too has developed a battery charging problem. I kept the Galaxy 500 with a view to tracking down the charging problem, it would most likely be a straightforward(?!) power component, transistor, capacitor or diode, on a long winter evening. Set the 500 up with a keypad, 1k resistors on all the inputs, a battery and then cleared the memory with the jumper switch. With no hardware modifications at all the 500 now charges the battery and even after several power cuts, I turned off the mains, it still charges and performs perfectly. Anyone got any ideas? Is it possible that the programming of the units could be causing the charging problems and the error BATT TEST FAIL? Unlikely I know, but there is something funny happening here. Am also interested in upgrading the 500 to the latest (for this panel) firmware. Thanks, Andrew (UK) Quote
GalaxyGuy Posted October 30, 2017 Posted October 30, 2017 Does changing the battery in the dimension panel resolve the issue? Don't assume the same fault - it may be the battery. The Dimension power circuitry is a decent design. If the panel is mounted in an area with poor ventilation, the temperature inside will be elevated and the battery lifetime reduced. Quote
MrHappy Posted October 30, 2017 Posted October 30, 2017 1 hour ago, AParsons said: Set the 500 up with a keypad, 1k resistors on all the inputs, a battery and then cleared the memory with the jumper switch. With no hardware modifications at all the 500 now charges the battery and even after several power cuts, I turned off the mains, it still charges and performs perfectly. but the PSU does'nt have the loading of running all the devices of your full system ? 1 hour ago, AParsons said: A new panel, a Galaxy Dimension 48C was fitted and within about 9 months it too has developed a battery charging problem. I'd assume a new battery with the new controls ? eg- warranty work ? Quote Mr Veritas God
al-yeti Posted October 30, 2017 Posted October 30, 2017 New panel , move on after 20years , I hear the old Nokia's type phone are making a come back though Quote
norman Posted October 30, 2017 Posted October 30, 2017 If all you want to do is make calls and text then I'd say you are much better off with an old Nokia 2 Quote Nothing is foolproof to a sufficiently talented fool.
al-yeti Posted October 30, 2017 Posted October 30, 2017 1 hour ago, norman said: If all you want to do is make calls and text then I'd say you are much better off with an old Nokia +10 Quote
AParsons Posted February 5, 2018 Author Posted February 5, 2018 Thanks for the input - had changed the battery and the problem on the original 500 persisted so we got a new Galaxy 48C installed. It is true that in my shed the Galaxy 500 is only running one keypad and not the detectors for a 4 bedroom house - although that should be a pretty modest load for the mighty 500. We called the engineer about the new battery charging problem and when he came it mysteriously went away and has not returned. Any idea were I can get a firmware upgrade for the original 500 - I can burn a PROM if need be. Quote
james.wilson Posted February 5, 2018 Posted February 5, 2018 I don't think proms are still available. I have a few 4.5x ones but need to keep em Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Nova-Security Posted February 5, 2018 Posted February 5, 2018 Which prom is it, does it start with 27 or 28 Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
