Guest Posted November 4, 2004 Posted November 4, 2004 Today, I've just been to a job where I fitted a dialler and yet again someone (dopey IT company) has plugged various items into the NTE. Obviously this comprimises the security offered by the line seize on the dialler. The NTE is a standard NTE5b (BT master socket with removable lower half and socket) but I keep seeing NTE5a (BT master socket with removable lower half with no socket)here and there and wondered if anyone knew of a source of these lower half blanks?
Security Technician Posted November 17, 2004 Posted November 17, 2004 Today, I've just been to a job where I fitted a dialler and yet again someone (dopey IT company) has plugged various items into the NTE. Obviously this comprimises the security offered by the line seize on the dialler. The NTE is a standard NTE5b (BT master socket with removable lower half and socket) but I keep seeing NTE5a (BT master socket with removable lower half with no socket)here and there and wondered if anyone knew of a source of these lower half blanks? 30311[/snapback] i know which u mean, seen a few of them on redcare installs etc, could always ask your friendly bt engineer nicely lol, u never know what might fall out the back of the van , i once got talking to one on a line swap on a redcare back in my intruder days and i ended up with a bag full of sockets and a drum of 4 core internal b cable, have you tried places such as mills who supply telecom gear, thier website
Guest Posted November 18, 2004 Posted November 18, 2004 could always ask your friendly bt engineer nicely lol, u never know what might fall out the back of the vanĀ , 31786[/snapback] Yep, thought that would be the answer, just wondered! I tried all the usual suppliers and nothing, not even as a non BT part. I haven't managed to collar a BT bloke recently but it's on my list for when I do.
Guest Posted May 18, 2006 Posted May 18, 2006 I think I've found a supplier of these lower half NTE5 blanks. If anyone is interested in some then please let me know as there is a minimum order quantity and I'm not really convinced that I'll use 200 of them!
Guest Posted May 18, 2006 Posted May 18, 2006 NTE5 Socket with blank detachable front Code = 314678 are you not using a type 80a /92a block terminal ?
Guest Posted May 18, 2006 Posted May 18, 2006 NTE5 Socket with blank detachable front Code = 314678 Yeah, but try getting one though on anything other than a new line, and even then it's not always a dead certainty that one will be fitted even if requested. are you not using a type 80a /92a block terminal ? Sometimes, depends on the application.
Guest Posted May 19, 2006 Posted May 19, 2006 Yeah, but try getting one though on anything other than a new line, and even then it's not always a dead certainty that one will be fitted even if requested.Sometimes, depends on the application. You get whats in the the van 80b, get it right I bow to your greater knowledge
