Mark Summers Brocklesby Posted November 14, 2017 Share Posted November 14, 2017 Fitted system 2weeks ago no problems all good programmed all ok just had call customer says zone 14 back door prom erro can’t set I’ve gone to site I’ve deleted zone relearn zone and 3 days later comes back to same fault did same thing delet relearn and new battery in device gone away within two hours back to same fault I’ve ordered new contact to replace but it bugging why is it doing this the door is only 10 foot away from panel ??? Any ideas anyone ? Quote Link to comment Share on other sites More sharing options...
PeterJames Posted November 14, 2017 Share Posted November 14, 2017 Swap the contact with another one if the fault moves with the contact its faulty Quote Link to comment Share on other sites More sharing options...
sjsturner Posted November 14, 2017 Share Posted November 14, 2017 I would suggest it’s faulty, is it a slimline contact or the big long one? Quote Link to comment Share on other sites More sharing options...
sjsturner Posted November 14, 2017 Share Posted November 14, 2017 I assume once you learnt it you gave it mesh time and it walk tests ok? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 14, 2017 Share Posted November 14, 2017 2 hours ago, sjsturner said: I assume once you learnt it you gave it mesh time and it walk tests ok? I hope hkc mesh is better than this ...... Quote Link to comment Share on other sites More sharing options...
sjsturner Posted November 14, 2017 Share Posted November 14, 2017 18 minutes ago, al-yeti said: I hope hkc mesh is better than this ...... Rick ‘o’ Shea is great, if you are replacing a device then it’s a slight drag waiting but there’s always things to do, on a new install I’m normally doing paperwork whilst that is going on. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 14, 2017 Share Posted November 14, 2017 You can't have a stable mesh network without each device establishing itself with each other. Quote Link to comment Share on other sites More sharing options...
Simlec Posted November 14, 2017 Share Posted November 14, 2017 1 hour ago, al-yeti said: I hope hkc mesh is better than this ...... It’s not all going to be mesh I was told just the data links, so existing wireless stays the same. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 14, 2017 Share Posted November 14, 2017 Ok I was told different devices Quote Link to comment Share on other sites More sharing options...
james.wilson Posted November 15, 2017 Share Posted November 15, 2017 as above Afaik the devices stay the same you add them as / if needed Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
