GalaxyGuy Posted November 26, 2017 Posted November 26, 2017 You never mentioned a tamper on 1001, so unless that zone is not being used, then no resistor required there. You aren't shorting the zones, you're just setting the zone permanently closed by placing 1k across the zone to ground (0v). Zones that are 1k are closed. Zones at 2k are open. On the G2, any higher or lower resistances are tamper. The resistance boundaries are in the manual. Here's the zones info for your G2: On the left block (RIO 0) zones are: 1001 1002 1003 1004 On the right hand block (RIO1) zones are: 1011 1012 1013 1014 - Resistor to 0v 1015 - Resistor to 0v 1016 - Resistor to 0v 1017 - Resistor to 0v 1018 - Resistor to 0v Quote
Jms Posted November 26, 2017 Posted November 26, 2017 (edited) As Galaxy Guy has explained. See attached photo. But cut your resistors down, I've left them long so you can see how to fit yours. Your resistors could also be green not blue. Edited November 26, 2017 by Jms Quote
Olympus_Jim Posted November 26, 2017 Author Posted November 26, 2017 Hi all, Many thanks for all your help it is much appreciated. I will fit the resistors as your photo shows as the panel came with a lot of resistors in the pack of which all are blue, and which I have used on the terminals within the keypad. Alarm is now operational and all I have to do now is configure the system for full set / night set, which will be my other job for today. Thanks again. James Quote
al-yeti Posted November 26, 2017 Posted November 26, 2017 On 26/11/2017 at 07:26, Olympus_Jim said: Hi all, Many thanks for all your help it is much appreciated. I will fit the resistors as your photo shows as the panel came with a lot of resistors in the pack of which all are blue, and which I have used on the terminals within the keypad. Alarm is now operational and all I have to do now is configure the system for full set / night set, which will be my other job for today. Thanks again. James Expand You mean you used a 680ohm in keypad ? Quote
Jms Posted November 26, 2017 Posted November 26, 2017 On 26/11/2017 at 11:27, al-yeti said: You mean you used a 680ohm in keypad ? Expand You have to use the end of line resistor in the keypad as al-yeti has noticed. See photo. Quote
norman Posted November 26, 2017 Posted November 26, 2017 On a G2 the eol is moot ime. Quote Nothing is foolproof to a sufficiently talented fool.
Olympus_Jim Posted November 26, 2017 Author Posted November 26, 2017 Hi all, Yes, apologies I checked the keypad and it is the 680 ohm resistor I have used in the keypad. I have another quick question if someone could help me. The new alarm is in the same position as an old system. I have gone for the wireless RF for all the detectors but to avoid the requirement to start chasing into walls I am utilising the old wiring from the panel to the bell box (which is also the original). However, the bell box is not in a good position and has been located for ease rather than function. My question is are then any wireless bell boxes on the market that are compatible with the G2 that will avoid me having to put chases through 3 rooms. Regards, James Quote
GalaxyGuy Posted November 26, 2017 Posted November 26, 2017 No, there's no wireless option for the Galaxy range. Best to hard wire it anyway. 1 Quote
Olympus_Jim Posted November 26, 2017 Author Posted November 26, 2017 Ok, thanks GalaxyGuy, looks like OH won't be too happy then as I will be chasing walls! Quote
al-yeti Posted November 26, 2017 Posted November 26, 2017 On 26/11/2017 at 14:30, Olympus_Jim said: Ok, thanks GalaxyGuy, looks like OH won't be too happy then as I will be chasing walls! Expand There are some universal options Quote
