phil039 Posted November 29, 2017 Posted November 29, 2017 Hi does any one know how to access the engineering mode on the pyronix conqueror panel ? I need to get zone two changed to access on entry but I can't find the info on any down loads for the panel only user down loads many thanks in advance for any advice Quote
aissecur Posted November 29, 2017 Posted November 29, 2017 Hi, sorry no codes are given out on here Quote
phil039 Posted November 29, 2017 Author Posted November 29, 2017 I'm not asking for codes I'm asking for an engineer's manual down load Quote
al-yeti Posted November 29, 2017 Posted November 29, 2017 4 minutes ago, phil039 said: Hi does any one know how to access the engineering mode on the pyronix conqueror panel ? I need to get zone two changed to access on entry but I can't find the info on any down loads for the panel only user down loads many thanks in advance for any advice Best thing call a local engineer to reset you codes, should cheapish Although I advise scrap it and change the panel for one thing more upto date Quote
phil039 Posted November 29, 2017 Author Posted November 29, 2017 I don't need to reset the codes tho I want to know how to change zone 2 to access without the alarm goin off every time I enter my garage Quote
aissecur Posted November 29, 2017 Posted November 29, 2017 (edited) Sorry but not default or programming information info is given out on here. If you want to work on the panel yourself you can always contact Pyronix for the manual But as Al-Yeti says its a very old panel and an upgrade would be a good route to take Edited November 29, 2017 by aissecur Quote
phil039 Posted November 29, 2017 Author Posted November 29, 2017 I don't need to reset the codes tho I want to know how to change zone 2 to access without the alarm goin off every time I enter my garage If codes etc etc can't be given out on here maybe some kind person may send me a email ? Quote
Hillbilly Posted November 29, 2017 Posted November 29, 2017 If its any help its the same programming as the Paragon E panel. Quote
MrHappy Posted November 29, 2017 Posted November 29, 2017 I look at the book for you..... But I'd prefer you to tw@t it off the wall with a claw hammer & buy a euro mini or similar 1 Quote Mr Veritas God
al-yeti Posted November 29, 2017 Posted November 29, 2017 1 hour ago, phil039 said: I don't need to reset the codes tho I want to know how to change zone 2 to access without the alarm goin off every time I enter my garage If codes etc etc can't be given out on here maybe some kind person may send me a email ? Requires codes either way , as above paragon e And twatting Quote
