Steve Jones Posted November 18, 2017 Posted November 18, 2017 I have had a gardtec 800 series alarm for many years and has been very well behaved......I have changed the battery myself as a precaution against it failing...I have two keypads LCD the one by the main exit door sometimes displays “ system in use please wait “ I wait for 30 seconds or so and it clears allowing me to set the alarm......it only happens when I use this keypad.....the other one is used every night to part set.....is it possible thie exit keypad has a fault.......? also I have the engineer code and need to use this while I remove a PIR for decorating..... it can’t remember the steps to set engineer mode....could someone help please. If I have to replace the exit keypad, is it still possible to get a new one ? Or is a used one ok thanks Quote
sixwheeledbeast Posted November 18, 2017 Posted November 18, 2017 Is the other keypad active when the main door one shows busy? Just silence with the user code when you remove the PIR, then reset when complete. Quote
al-yeti Posted November 18, 2017 Posted November 18, 2017 Buy new , if cost of keypad is example £100 survey it's worth it to protect why you have system Quote
MrHappy Posted November 18, 2017 Posted November 18, 2017 1 hour ago, Steve Jones said: it can’t remember the steps to set engineer mode....could someone help please. enter code, "do you want the set system" press no "do you want to program system" press yes 1 hour ago, Steve Jones said: I have had a gardtec 800 series alarm for many years and has been very well behaved...... new rkp is be around £90 for the part, I'd bin the lot of it Quote Mr Veritas God
datadiffusion Posted November 18, 2017 Posted November 18, 2017 (edited) Seems like a spurious fault to me, when we used to install these, and had around 100 on the books, I had never heard of this fault, assuming it is indeed the case that the other keypad hasn't recently been used when the message appears. Until recently I'd have been reluctant to suggest binning these systems, but assuming it is an 800 rather than the later and better 816, I'd say the time is probably nigh for these. That said in those days it was relatively new & not a potentially 20 year old piece of kit... Edited December 8, 2017 by datadiffusion Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Steve Jones Posted December 8, 2017 Author Posted December 8, 2017 Have a few questions, please..... I have a rather old gardtec 800 system, with two keypads ( ace I think ) recently the exit expand sometimes displays “ system busy please wait” when setting the alarm.....I then thought I would test the system, but the engineer code I have used in the past does nothing, after pressing the code it just shows unset ?? Are these issues likely related ? Could it be data corruption or a hardware fault ( keypad and or control panel ) As the system is old, I am considering powering down the system and trying to reset the engineer code, if ok then I could replace just the keypads.......but the board is 15-25 years old... Any comments / suggestions on my upgrade repair path ? Thanks Quote
al-yeti Posted December 8, 2017 Posted December 8, 2017 When you power down , remove keypads and control panel And replace with something upto date a new Quote
sixwheeledbeast Posted December 8, 2017 Posted December 8, 2017 Merged this thread with your first post as questions where asked with no response. It's likely it just needs someone who knows what they are doing to look at it. Quote
Hillbilly Posted December 8, 2017 Posted December 8, 2017 If your happy and want the same system then I would replace with a Gardtec 600. Quote
aissecur Posted December 8, 2017 Posted December 8, 2017 I do know if you are entering a code in one keypad then the other keypad will say System in use... Its is possible that the keypads may need relearning, I do know on the 595 / 600 / 601 etc you have to learn each keypad (I think from memory you hold yes / no at each keypad and a number is assigned) Or as what others have suggested, the 800 system is quite old now... Maybe an upgrade may be the best way forward Quote
