sixwheeledbeast Posted December 26, 2017 Posted December 26, 2017 On 26/12/2017 at 13:53, MattS said: Do you know of any good guides for programming home alarm systems? I've downloaded the manual from Honeywell but I wouldn't say its the simplest to follow. Expand If you cannot follow the the instructions in the engineering manual, maybe consider getting someone in. If the timer is only inconvenient then consider that defaulting may make the system unusable like I say above. There is no visible age on the battery so that is likely to need replacing, if not serviced in a while it's worth having the full system checked. On 26/12/2017 at 14:02, MattS said: I've checked the forum root (http://www.thesecurityinstaller.co.uk/community/) as well as this subforum root and cant find any sticky's in relation to posting manuals. Can you let me know where on the forum main page I should be looking at in relation to the rules about posting manuals. Expand http://www.thesecurityinstaller.co.uk/community/guidelines/ Section 12 - Do NOT post security control equipment defaulting information We do not allow the sharing of engineering manuals, default codes or defaulting instructions here for security reasons. Quote
MattS Posted December 26, 2017 Author Posted December 26, 2017 @sixwheeledbeast thanks for the advice and the guidelines link. I'll make sure to read before posting again. Best M Quote
sixwheeledbeast Posted December 26, 2017 Posted December 26, 2017 No problem, let us know how you get on. Quote
Nova-Security Posted December 26, 2017 Posted December 26, 2017 800L + Quote www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
