17 minutes ago, MattS said:
Do you know of any good guides for programming home alarm systems?  I've downloaded the manual from Honeywell but I wouldn't say its the simplest to follow.
If you cannot follow the the instructions in the engineering manual, maybe consider getting someone in.
If the timer is only inconvenient then consider that defaulting may make the system unusable like I say above.
There is no visible age on the battery so that is likely to need replacing, if not serviced in a while it's worth having the full system checked.
I've checked the forum root (http://www.thesecurityinstaller.co.uk/community/) as well as this subforum root and cant find any sticky's in relation to posting manuals.  Can you let me know where on the forum main page I should be looking at in relation to the rules about posting manuals.
http://www.thesecurityinstaller.co.uk/community/guidelines/
Section 12 - Do NOT post security control equipment defaulting information
We do not allow the sharing of engineering manuals, default codes or defaulting instructions here for security reasons.
