5 minutes ago, virdi said:
Yes ...I believe so. It also done the funny beep.
The point I of walk testing is to ensure that the detector that is activating is the detector that is displayed on the panel. For example say the garage is programmed in zone 5 and the landing is zone 4. But you accidentally wired the landing in 5 and the garage in 4, when the alarm goes off you will be looking in the wrong place.
  • Upvote 2
Many thanks. I will double check this also.
  • 3 weeks later...
Posted (edited)
Hi all,
This issue finally got resolved .... I replaced the cable from the Garage PIR to the Panel and also replaced the PIR.
No more false alarms so far.
Thank you to all that helped and advised
Edited by virdi
