Just connect the leave side of the loop see what devices are there/missing then diss the leave side of the loop and connect the return side of the loop and repeat if all devices are seen the panels goosed
  • Upvote 1
Hardcore and simple
  • 7 years later...
2 hours ago, sai said:
How to clear loop integrity fault. No short in loop
just resetting should clear a fault free system....
remove 1 leg of loop at panel you should have + & - returning on the cables which are no in the panel?
if so check panel by removing field wiring & link loop out you should have every item on the loop missing but no loop fault ?
if not walk the system loop for yellow short led / check heads & external sounders for leaks & check every thing is tight ?
