Texecom Premier Elite - Cut Cable :(
6 hours ago, al-yeti said:
Due to location and space I would go with solder and any type of wrapping , not gift wrap though
Image result for stormzy
  • Replies 31
  • Views 7.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Due to location and space I would go with solder and any type of wrapping , not gift wrap though
  • A regular soldering iron will be fine, if you are unsure have a practice first on some old spare cable.   Lots of tutorials on YT.
  • sixwheeledbeast
    sixwheeledbeast
    60/40 electronics solder or most stock the lead free equivalent, flux is in the solder core (rosin). Do not use plumbing solder it's not suitable.
Posted Images
2 hours ago, james.wilson said:
Id solder and heat shrink. Melting temp of ali is quite high compared to a soldering iron. Its not copper pipe you dont need a blow torch
QFA
I wouldn't use wago levers! They're designed for mains rated cables and I'm pretty sure would chewup CCA
Thanks for everyone's input - are we thinking that a regular soldering iron will be able to solder the joint OK? I didn't think it would work. I do have a blow torch for plumbing duty but that is probably not right in this application.
Thank you for that - I believe there is an offcut of CCA lying about, I will have a go on that. Do I need any particular flux or solder? I have regular plumbing flux and solder, not sure if this is correct for this specialised application?
OK great. I might have some electronics solder already. I know that I definitely have lead and lead free solder for plumbing use but that won't be suitable as mentioned above. Also it is on a large cumbersome reel.
Last q - how do I put the system into standby / switch it off - the wiring is live, I don't want to short / damage anything! It's a Texecom Premier Elite 24.
Edited by MarkJohnson
Safest way is to enter engineer mode and disconnect the cable fully from the panel end, take a clear photo of the connections first to make connecting back up easier.
