Mark123 Posted January 19, 2018 Posted January 19, 2018 (edited) I am looking for a low cost wired system for a double garage - 2 "up and over" doors and one side-door. Any recommendations? Edited January 19, 2018 by Mark123 Quote
norman Posted January 19, 2018 Posted January 19, 2018 Could you add it on to your home system? Quote Nothing is foolproof to a sufficiently talented fool.
Mark123 Posted January 19, 2018 Author Posted January 19, 2018 I was planning a wireless system for the house and a seperate wired system for the garage. (Not sure how the metal doors would affect the radio signals from the door sensors and decor isn't an issue in the garage). I also might want others to access the garage without having to disarm the house. Quote
norman Posted January 19, 2018 Posted January 19, 2018 This could all be achieved by a Texecom Hybrid system with a couple of keypads for both area's, at least then you get notification in the house when the garage is being turned over. Can you get a cable to the garage from the house? Quote Nothing is foolproof to a sufficiently talented fool.
al-yeti Posted January 19, 2018 Posted January 19, 2018 This could be achieved with many systems Quote
Mark123 Posted January 19, 2018 Author Posted January 19, 2018 Hmm - wire from the house to the garage would be tricky to do securely I think. Quote
sixwheeledbeast Posted January 19, 2018 Posted January 19, 2018 Any system with areas could be set to work like two systems. You could wire with appropriate containment or use a hybrid system but it all comes down to cost. Quote
PeterJames Posted January 19, 2018 Posted January 19, 2018 4 hours ago, Mark123 said: Hmm - wire from the house to the garage would be tricky to do securely I think. Does it matter? cutting the wire would set the alarm off its a DIY system at the end of the day. Quote
