AB 1950 Posted January 25, 2018 Posted January 25, 2018 Tenanted flat where outside alarm box flashing. number 8 illuminated on upper set of numbers on keypad. Neither owner nor tenant can recall security code. Any help or advice welcome. Quote
norman Posted January 25, 2018 Posted January 25, 2018 The strobe will continue to flash until the system is reset, to do this you would require the user code, speak to the landlord would be my advice. Quote Nothing is foolproof to a sufficiently talented fool.
AB 1950 Posted January 25, 2018 Author Posted January 25, 2018 Thanks Norman , but as I stated in the original post neither the tenant nor the owner (landlord) know or remember the user code. Quote
sixwheeledbeast Posted January 25, 2018 Posted January 25, 2018 Landlord had better call an engineer out then. Quote
AB 1950 Posted January 25, 2018 Author Posted January 25, 2018 Sussed out the security code . External light seems to have stopped flashing however the upper number 8 on the keypad is flashing. What does this mean? Quote
norman Posted January 25, 2018 Posted January 25, 2018 Upload a photo of the keypad or model number, guessing a 800l or similar. Quote Nothing is foolproof to a sufficiently talented fool.
AB 1950 Posted January 25, 2018 Author Posted January 25, 2018 C and K Securitech C 023-203 Iss 1 . Looks like this attachment . Quote
james.wilson Posted January 25, 2018 Posted January 25, 2018 what happens when you enter code followed by # Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
AB 1950 Posted January 25, 2018 Author Posted January 25, 2018 Nothing happens . The upper number 8 continues to flash after the code # is pressed. Quote
norman Posted January 25, 2018 Posted January 25, 2018 Are you sure you have the correct code? Try inputting the 4 digit code again, does it begin to set? Quote Nothing is foolproof to a sufficiently talented fool.
