Hi I have A 4 camera floureon cctv system I lost the night vision on all 4 cameras unplugged power supply to check connections plugged power supply back in now system has red light on front and won’t come on could it be the power supply has packed up
You have two power supplies?
One for cameras one for recorder?
What do you mean lost all night vision? Do you mean you had day pictures but no pictures at night?
Maybe power supply being overloaded when ir lamps come on , so possibly power fault
I could see pictures at night but very dark looked outside at camera no red leds showing so switched off power supply check cables switched back on no pictures at all and red light on front of box showing power off there is only one power supply fits in to a set off five leads one for box four for cameras
No had 14 months I could see pictures at night but very dark looked outside at camera no red leds showing so switched off power supply check cables switched back on no pictures at all and red light on front of box showing power off there is only one power supply fits in to a set off five leads one for box four for cameras
No had 14 months ago just felt power supply and it’s cold normally hot will buy another power supply and try that do you think that could be my problem thanks
Easy check would be to down power three cameras and see if one works properly. Those cheapo kits on ebay are not really built to last though, 14 months is a good two month past the warranty period so you did quite well.
