Andy81 Posted February 13, 2018 Posted February 13, 2018 Hello, I have a 9651 panel which has been down powered for 12 months plus. The bell box was missing.... I have replaced the bell box and powered up the system and installed a new battery. When I try to exit engineering mode the panel reports a battery missing fault every time. Fuses are all OK and battery is brand new. Also tried the battery kickstart procedure. Any thoughts appreciated Thanks Andy Quote
al-yeti Posted February 13, 2018 Posted February 13, 2018 On 13/02/2018 at 20:10, Andy81 said: Hello, I have a 9651 panel which has been down powered for 12 months plus. The bell box was missing.... I have replaced the bell box and powered up the system and installed a new battery. When I try to exit engineering mode the panel reports a battery missing fault every time. Fuses are all OK and battery is brand new. Also tried the battery kickstart procedure. Any thoughts appreciated Thanks Andy Expand Probably faulty panel, Replace it , it's cheap anyway but I would pick something more upto date while your in the mood to spend Quote
Andy81 Posted February 13, 2018 Author Posted February 13, 2018 Yeah cheap enough for a replacement with one keypad but the replacement firmware version won'the accept the 9930 keypads (3 of) already installed. The keypads are 50 quid each... Quote
Andy81 Posted February 13, 2018 Author Posted February 13, 2018 It is going to get replaced anyway. Just curious to see if anyone has seen this before or if I'm missing a trick. Quote
al-yeti Posted February 13, 2018 Posted February 13, 2018 On 13/02/2018 at 20:33, Andy81 said: It is going to get replaced anyway. Just curious to see if anyone has seen this before or if I'm missing a trick. Expand No Trick I meant forget this model , if you really like scantronic move to the ion but not the ion16.... Quote
Andy81 Posted February 13, 2018 Author Posted February 13, 2018 (edited) Im not really a fan of scantronic. If I had my way I'd replace it with a texecom premier. It's the cost for the customer I'm trying to save. Why not the ion 16? Edited February 13, 2018 by Andy81 Quote
al-yeti Posted February 13, 2018 Posted February 13, 2018 On 13/02/2018 at 20:54, Andy81 said: Im not really a fan of scantronic. If I had my way I'd replace it with a texecom premier. It's the cost for the customer I'm trying to save. Why not the ion 16? Expand 16 on its merry way out I thought Quote
