How do I default pyronix vocalizer
Guest paulmatt
Guest paulmatt
hi
I am trying to default a pyronix vocalizer
I can not get hold of the install manual.
anybody got an idea??
first time using one.
thank in advance
paul
The default engineer code is 5678 so plug a phone into the socket, press 00
You hear "Please enter security code" press **5678 if the code has not been changed you should hear "Menu"
Press keys 9,3 and that will default the Vocaliser programming.
31009[/snapback]
Or, as Paul says, go and get a proper one. Menvier SD1 /2 or Texecom Speech Dialler.
