Ghost Posted March 10, 2018 Posted March 10, 2018 Guys i havent installed a sd1+ for a few years now but i did one for a friend. On the sd1 dialler do i wire it to A or o/p1 (next to 12v supply)? I’ve had a memory loss lol but didnt want to blow it. Thanks Quote
Ghost Posted March 10, 2018 Author Posted March 10, 2018 Come on guys, surely someone has fitted an SD1+ dialler that can help?? Quote
norman Posted March 10, 2018 Posted March 10, 2018 Just a guess but o/p1 will be an output, not an input... What are you wiring and didn't it come with a manual? Quote Nothing is foolproof to a sufficiently talented fool.
al-yeti Posted March 11, 2018 Posted March 11, 2018 1 hour ago, Ghost said: Guys i havent installed a sd1+ for a few years now but i did one for a friend. On the sd1 dialler do i wire it to A or o/p1 (next to 12v supply)? I’ve had a memory loss lol but didnt want to blow it. Thanks Trigger A yes , (NOT A for phone line ) Just be sure to record message A correctly Quote
Ghost Posted March 11, 2018 Author Posted March 11, 2018 8 hours ago, norman said: Just a guess but o/p1 will be an output, not an input... What are you wiring and didn't it come with a manual? 8 hours ago, al-yeti said: Trigger A yes , (NOT A for phone line ) Just be sure to record message A correctly Thanks i just left a message on phase 0. I’m wiring it off a G2-12 galaxy. But when I wired it to A it was ok but when we set the alarm it was calling. So it calls when bells trigger and when we set Quote
bm99 Posted March 29, 2018 Posted March 29, 2018 On 3/11/2018 at 08:14, Ghost said: Thanks i just left a message on phase 0. I’m wiring it off a G2-12 galaxy. But when I wired it to A it was ok but when we set the alarm it was calling. So it calls when bells trigger and when we set where is trig a wired into on the galaxy? probably need to change output type from calling when set Quote
al-yeti Posted March 29, 2018 Posted March 29, 2018 On 3/11/2018 at 08:14, Ghost said: Thanks i just left a message on phase 0. I’m wiring it off a G2-12 galaxy. But when I wired it to A it was ok but when we set the alarm it was calling. So it calls when bells trigger and when we set Just connect the trigger to the bell trigger Quote
