Are there particular issues to be aware of when doing a Texecom Elite firmware upgrade.  For example the documentation says disconnect the power and reconnect it before starting.  I assume this means both mains power and battery power?  If so is there a chance that the internal or external sounders will go off?
You can't flash a powered down panel.
There are certain caveats on some versions of firmware but it's similar rules as flashing/updating any device firmware.
If major version change you will need to default. Sounders may sound for a second or so when switching between Prog and Run.
