Hello,
I've got a Galaxy MK7 keypad giving a keypad tamper. The tamper switch on the rear of the keypad is not being adequately pressed down by the mounting plate and accompanying tamper peg. Does anyone have any advice on a short term solution for this issue?
Regards,
        Jack
17 minutes ago, jackaddressable said:
Hello,
Regards,
        Jack
Long term solution piece of card inside
Or make wall flat
Or check wall plugs not protruding and tap them in slightly
And so on
Well, I've been an alarm engineer for as long as I can remember and what has been suggested, especially the first answer is the way to go.
J, what do you think should be done then?
Please put me and hundreds of others right then.
Calm down calm down I dont think he meant anything by it
What you on about dude?
12 hours ago, jackaddressable said:
Okay, thanks. That's fine, will do. It isn't the best, but will make do. Thanks mate.
Yes dude you are correct not the best , these keypads can be testing lol , a freshly plastered wall could still be slightly bent and cause a problem, plus customer won't always for a new keypad never really used the mk8 might be other option....
2 hours ago, GMill said:
I've found the little white plugs which come with some wall sockets/switches to cover the screw hole fit nicely on that little peg :)
Ah good idea , you get title of clever dude
Although I will look for them on ripping them out for the hkc lol
Honeywell should have made those tampers a bit better. From what I've seen here, quite a few have had this problem. I'm not trying to disapprove of the card method etc, I just think that it's a shame for engineers and installers alike to have such a basic problem. I'm more annoyed that there is a problem, a solution is a solution.
