MrHappy Posted April 15, 2018 Posted April 15, 2018 I'd say your buying the "Wong" stuff Quote Mr Veritas God
norman Posted April 15, 2018 Posted April 15, 2018 Horee sheet! 1 Quote Nothing is foolproof to a sufficiently talented fool.
CARETAKER46 Posted April 15, 2018 Author Posted April 15, 2018 I wait till tomorrow or Tuesday for the answer for Hikvision and Hikwatch. Quote
al-yeti Posted April 15, 2018 Posted April 15, 2018 4 hours ago, MrHappy said: I'd say your buying the "Wong" stuff Purple drive is good though for stuff Quote
sjsturner Posted April 16, 2018 Posted April 16, 2018 7 hours ago, al-yeti said: Purple drive is good though for stuff +1 WD purple drives are good. Quote
sixwheeledbeast Posted April 16, 2018 Posted April 16, 2018 Forgetting about the "quality" and "brand" of the gear ... 4mm fixed lens isn't going to be suitable for this type of thing. I have always used WD Drives and WD Purples are pretty standard for 24/7 on applications. Generally I feel your wasting your time trying to point a camera onto public property, using neighbours walls, into a place you can't guarantee you will park on. The footage you will get will be pretty minimal too as it's side on and unlikely to identify anything. I get the feeling most companies would walk away from this job possibly why you are getting so little feedback. Quote
petrolhead Posted April 16, 2018 Posted April 16, 2018 1 hour ago, sjsturner said: +1 WD purple drives are good. If its genuine. Purple labels are pennies. Quote
sjsturner Posted April 16, 2018 Posted April 16, 2018 5 hours ago, petrolhead said: If its genuine. Purple labels are pennies. Yeah that did cross my mind too. Quote
sixwheeledbeast Posted April 16, 2018 Posted April 16, 2018 Great thing about WD is you can check your Serial Numbers are valid and within warranty date online. https://support.wdc.com/warranty/ 1 Quote
sjsturner Posted April 16, 2018 Posted April 16, 2018 1 hour ago, sixwheeledbeast said: Great thing about WD is you can check your Serial Numbers are valid and within warranty date online. https://support.wdc.com/warranty/ Didn’t know that, thanks Quote
