Yes the Neighbour fine with it, as they are getting free security as well and free of charge.
so it will go through Neighbour walls and same height Bt line, so it will not interfere with Long Ladders
So what's distance from nearest camera point to where car is parked , I assume distance becomes shorter?
Maybe do an overhead drawing
By the way if your going DIY hiwatch is probably the equipment you may want to use , but with a full size recorder not the little square box in some kits , they are hybrid versions so you can fit diff cams to them depending on what you need
Shame you don't have budget £2500 ? Do it once get contractor in?
Your far from Manchester ? I sure someone near you can give you a quote less hassle for you but whatever DIY it if you have to
I kind of get it I think , although alley way , building is high enough to mount a camera which isn't to easy to get to , few spikes under it will help
Distance will become shorter from the camera to the car about 20 metres. Distance from my house to 50metres.
is this another brand Hiwatch or are you talking about Hikvision ?
You have hiwatch above in your list, it's DIY for hikvision now
Also I was pretty sure the hik7204 etc is all hiwatch, you can only buy the DIY range of hiking that's what there selling you and it will do the job
Where you mount the car camera you may need two
One giving a wide view and another giving a close up
3 minutes ago, al-yeti said:
Also I was pretty sure the hik7204 etc is all hiwatch, you can only buy the DIY range of hik called hiwatch that's what there selling you and it will do the job
Thanks Al yeti.
What about the below brand ANNKE , are they any good ?
the reason I am asking it around £350
ANNKE 8CH 1080P HD-TVI Realtime Surveillance DVR Recorder System, One 2TB HDD Included, with 8x 1080P IP66 Weatherproof Camera System, Superior IR LED Night Vision, HD Over Analog/BNC, Cloud Storage, Smart Playback
51 minutes ago, CARETAKER46 said:
Thanks Al yeti.
Forget that total waste of time
Annke
Swamn
Maplins....
Screwfix....
All will give you trouble , at least with hikvision it's based around the pro-diy gear and now they have DIY gear , I say that because that's what there game plan was before
But it's still worth getting it fitted just to remind you of that lol
