skywalker Posted April 25, 2018 Posted April 25, 2018 Hi, i've been installing loads of the hikvision POC cameras which support Telementry over Coax, even on the statics. This is used to get into the camera menu to adjust resolution, framerate, WDR, etc. It can be done fine from the DVR or the web interface, but when using IVMS4200 or the HIK connect app, I get an error saying the device does not support PTZ! I'm running the latest version of everything - I get this error on all my systems and could do with it working to save an hour round visit to site! on the hik connect app i can change zoom, but it doesn't give me iris or focus options which is how you navigate the menu! TIA! Quote
Amps Posted April 25, 2018 Posted April 25, 2018 No idea mate but POC is fantastic! Do you change the WDR settings much? 1 Quote
petrolhead Posted April 25, 2018 Posted April 25, 2018 Have you tried ivms 4500, call preset 95? Quote
skywalker Posted May 31, 2018 Author Posted May 31, 2018 On 26/04/2018 at 00:54, petrolhead said: Have you tried ivms 4500, call preset 95? yep, and i can get into the menu, but there's no option to change iris which is how you select menu options! :"( On 25/04/2018 at 20:52, Amps said: No idea mate but POC is fantastic! Do you change the WDR settings much? yeah, i switch it on for nearly every camera i install. reduces quality a bit but at least you cans ee what's going on! Quote
petrolhead Posted May 31, 2018 Posted May 31, 2018 2 hours ago, skywalker said: yep, and i can get into the menu, but there's no option to change iris which is how you select menu options! :"( yeah, i switch it on for nearly every camera i install. reduces quality a bit but at least you cans ee what's going on! Other than the iris button next to the preset button you mean? Quote
satsuma01 Posted June 5, 2018 Posted June 5, 2018 The iris button on ivms 4500 is the fourth one along on the screen shot attached the red thing is the joystick enable that and the menu above comes up going from left to right the controls are autorotate camera -zoom control-,focus control- iris control - presets menu Quote "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
satsuma01 Posted June 7, 2018 Posted June 7, 2018 Yes that was taken about twenty minutes after the filters were cleaned and washed out so that's why it was a murky picture but yes there is a camera in the fish pond Quote "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
skywalker Posted July 7, 2018 Author Posted July 7, 2018 On 05/06/2018 at 17:13, satsuma01 said: The iris button on ivms 4500 is the fourth one along on the screen shot attached the red thing is the joystick enable that and the menu above comes up going from left to right the controls are autorotate camera -zoom control-,focus control- iris control - presets menu Thanks, but when using IVMS4200, I get an error saying the device does not support PTZ! and there is no iris option on HIK connect :( Quote
BUSTER Posted July 9, 2018 Posted July 9, 2018 You may need a firmware update Quote Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
