All down to if it's wired DP or EOL. More systems are wired EOL, inverting the wires shouldn't make a difference so maybe something is loose/shorting out.
Selectable you will have to make sure they are compatible with your panel normally you cut a link within them, or you can get ones with screw terminals which you can fit your resistors in.
  • Upvote 1
Thankyou
the picture here is the way I wire it up first but had a continuous tamper ....
then swopped the yellow and black, as per a DIY site...and it worked !!!
swapping the colours around make no difference to the circuit,
your picture shows the strands of the cable touching.... that is probably why it was in tamper
  • Upvote 2
On 14/05/2018 at 17:41, Calibra said:
Hello
i had the black and yellow wire swopped.....
now tamper has cleaed and all,ok...
would still like to know about the selectable resistor contacts ?
thanks for all the help
Wires being swapped shouldn't have caused an issue though
Lol missed your post somehow , although I didn't look for strands which was going to be my next comment
Still training .........
  • Upvote 1
The strands along with the core of the yellow wire need to go correctly under the screw also, basic stuff needs a bit of practice.
It also looks as though you have nicked the yellow insulation.
Practice makes perfect - in some cases, joke,  :genius:
magpye
