Guest donwilsonuk Posted August 25, 2003 Posted August 25, 2003 I am new to this forum but have come here in search of a keypad for XL6 ,is this something I can buy seperate ? many thanks Don
Service Engineer Posted August 25, 2003 Posted August 25, 2003 I dont think you can still buy the XL6 keypad membrane, but I think you can fit an external keypad so if all else fails you can use the one off the Accenta 8, only drawback being that the keypad shows zones 1 to 8 instead of 1 to 6. £21.95 + P&P Power Saver Website or £17.25 + P&P TLC Electrical Website ........................................................ Dave Partridge (Romec Service Engineer)
JB_ Posted August 25, 2003 Posted August 25, 2003 XL6's could take keypads? You may wanna check that.
Service Engineer Posted August 25, 2003 Posted August 25, 2003 Oh well we all get confused from time to time. The new OPTIMA, The Accenta`s and the New G3 Versions can all take keypads. But your right, The older Optima XM`s and XL`s cannot. ........................................................ Dave Partridge (Romec Service Engineer)
Guest kenny james Posted August 26, 2003 Posted August 26, 2003 you can get some of the older ade stuff from www.mas-uk.co.uk this is a supplier close to me on the wirral were i obtain some of the pcb boards for older models,they are very limited at the moment on the older models might be worth a check anyway tel:0151-630-0000 hope this helps ken (k alarms)
Guest kenny james Posted August 26, 2003 Posted August 26, 2003 B) thats the problem with the ade on board keypads the ribbon cable would eventually wear it self out its a shame they didnt invest in ribbon cable alot thicker than the wafer thin cable supplied which attached the keypad to the pcb board maybe this is why they made the later models were they could be connected to a seperate rkp?
