Hi,
I have wired in a roller shutter door to one of the relays on the net2 unit and on the programme set it to toggle. It will open the door but wont close it. The roller door unit is set right.
Maybe it shouldnt toggle?
or i have put the wires from the door in the wrong way.
Ideas appreciated
Posted (edited)
It has a laser break for safety installed.
The problem we keep having is that its set on timer down but the moment the time lapses it starts to raise again??
Edited by forumflyer
id assume then it wants a pulse to open? then time out and reclose?
How have you interfaced the two , diagram? I just interested on the roller control side , meaning how did you wire it? Onto the shutter switch?
