karl taylor Posted June 5, 2018 Posted June 5, 2018 Hi. Just wanting some information on best way to temporary remove a wired room motion sensor . Need to remove it for plastering work . Am i correct in thinking its a straight forward matter of putting alarm in to engineer mode Then carefully disconnect each wire in turn .and tape them up seperatly and then when finnished reconnect and then put alarm out of engineer mode? Or do i need to take out a fuse in the panel to stop shortages first? Any help appreciated . Quote
karl taylor Posted June 5, 2018 Author Posted June 5, 2018 Hi. Alarm is a risco cpx 8l I have been told by my plaster that he needs the keypad removing from a wall that needs replastering. Can any one tell me the best way to do this. Am i correct in assuming i just have to enter the engineer code on the key pad first then i can diconnect it from the back . Then when i am ready to reconnect it connect it back from the back and then take alarm out of engineer mode? Thankd all... Quote
PeterJames Posted June 5, 2018 Posted June 5, 2018 Hi welcome to the forum, Ive merged your topics, there is no need to open a new topic for two questions. Question 1 cut the 12v pos and dont worry if you short any of the others. Question 2 The keypad can be removed from the wall with the cable still attached, if its likely to get wet put it in a plastic bag and seal it. If your alarm is under a service contract you may invalidate your contract by carrying out these works yourself Quote
al-yeti Posted June 5, 2018 Posted June 5, 2018 8 minutes ago, PeterJames said: Hi welcome to the forum, Ive merged your topics, there is no need to open a new topic for two questions. Question 1 cut the 12v pos and dont worry if you short any of the others. Question 2 The keypad can be removed from the wall with the cable still attached, if its likely to get wet put it in a plastic bag and seal it. If your alarm is under a service contract you may invalidate your contract by carrying out these works yourself Ah plastic bag is the one , although it works for the pir sometimes aswell Quote
karl taylor Posted June 10, 2018 Author Posted June 10, 2018 Hi. Had a bit of chew in with this. Put alarm in to engineer mode. Then disconnected the wiring to the pir in room . Managed to touch the red wire to some thing when pulling cables back out of pir. It set the outside siren off saying tamper 8x on the keyboard. Outside bell box went off for about 30 minutes. Had a look inside control panel . 1amp fuse is blown , other two fuses the 250mill amp and the 2amp are ok. Went back in the house and now have noticed the keypad is dead. Went to try and get a 1amp fuse . No chance on a sunday.... My question is is the siren likely to go off again or not ? It hast for last 6 hours but thinking it might just be charging up then will go off? I have individualy taped the 5 wires up from the pir . Nothing i can do tonight Apprently there are varous speeds of 1amp fuse. . From F to T version . So will go to electrical factors tomorrow if i get chance with blown one . Just hope alarm wont go off tonight. Alot to be said about bagging the sensors . Well to late now. Think will be ok?? Quote
james.wilson Posted June 10, 2018 Posted June 10, 2018 I would say the external fail safe timer has stopped it for now Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
karl taylor Posted June 10, 2018 Author Posted June 10, 2018 I never knew there are 3 different types of 1amp fuse. Slow speed Fast speed and delayed Carnt just fit a 1amp fuse from halfords . The fuse says 1amp speed F. 20mm glass fuse. Going to get some 2amp speed T And some 250ma speed F fuses as well. Is it likely that the siren will go off again until i get a new fuse????? Quote
al-yeti Posted June 11, 2018 Posted June 11, 2018 (edited) 4 hours ago, karl taylor said: I never knew there are 3 different types of 1amp fuse. Slow speed Fast speed and delayed Carnt just fit a 1amp fuse from halfords . The fuse says 1amp speed F. 20mm glass fuse. Going to get some 2amp speed T And some 250ma speed F fuses as well. Is it likely that the siren will go off again until i get a new fuse????? If it triggers some other way then yes possible In terms of bagging sensors , can't see a problem with it, not sure why you took it apart to bag it , unless cable short , you should carry fuses if you the work regular geezer , I have a box , if you don't have exact you could get away with lower amperage fuse , just don't use fag paper , fag paper still available anyone ? Of course if it's the hold off supply fuse then as jw says Edited June 11, 2018 by al-yeti Quote
karl taylor Posted June 11, 2018 Author Posted June 11, 2018 Well not gone off last night. Power to alarm i have left on . Cable was too short so couldnt bag it. Order some fuses from rs components and a few spares of correct grade. Hopefully it wont go off . Quote
karl taylor Posted June 11, 2018 Author Posted June 11, 2018 My only concern now is a neighbour told me before i remove the fuses to check them to switch off the power to the alarm at the fuse box and disconnect the battery back up first. This i did. Power was off to alarm for about 30 mins. My concern is i might have lost all the settings to the alarm when i put the blown fuse back in? Hopefully not. If i have it will all need reprogramming . Would this be the case?? Quote
