Guest carldp Posted November 8, 2004 Posted November 8, 2004 Our control panel has recently started bleeping when someone walks in front of one of the sensors, eventhough the alarm is 'off'. When looking at the control panel it shows that the zone 2 light has been activated, but the actual house alarm has not gone off...becuase the alarm isn't on!! How do I reset the alarm so that the 'bleeping' stops? Thanks for any help. carldp.
Brian c Posted November 8, 2004 Posted November 8, 2004 Our control panel has recently started bleeping when someone walks in front of one of the sensors, eventhough the alarm is 'off'. When looking at the control panel it shows that the zone 2 light has been activated, but the actual house alarm has not gone off...becuase the alarm isn't on!!How do I reset the alarm so that the 'bleeping' stops? Thanks for any help. carldp. 30770[/snapback] It sounds like you have 'chime' enabled on zone 2. Here is the User Guide, it will tell you how to disable it Accenta_8_user.pdf If you don't know......ask.
Guest carldp Posted November 8, 2004 Posted November 8, 2004 Just the job! Many thanks for your help. carldp.
