electrocam Posted November 8, 2004 Posted November 8, 2004 Has anyone experianced problems with the focus on Dennard 2050 and similar models, where the camera will work fine for a few hours or days, and then the focus will get permanantly stuck in the near or too-far position, you can still move the focus, but only from out of focus to really out of focus. I've seen this on a 2050 that used the Sony FCB-IX470P, had to send it back and have a new cam block fitted to it, the new cam block was of the FCB-EX480P variety. Sony states that the ZoomFocus initialize command should be sent every 24 hours to the camera block if the camera is being used continuously. The 2050's are not programmed to send this command so maybe that adds to the problem. As some of you may know I use this 2050 along the seafront in a webcam application, (link below) - I've programmed my control software to send this ZoomFocus init command to the camera block, so we'll see how long it lasts... http://www.exmouthcam.co.uk Trade Access/CCTV Member
BUSTER Posted November 9, 2004 Posted November 9, 2004 We've had the same problem. Dennard called it a 'sticky lens'. They said that if the camera is doing a continous tour the lens needs to be 'exercised' i.e. zooming fully in and out as part of the tour. Tried that - didn't work, had to have a new camera module fitted. Still got the old camera module if anyone knows how to cure the problem! Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
electrocam Posted November 9, 2004 Author Posted November 9, 2004 I don't suppose there's any chance I could cheaply buy the faulty camera block off of you ? I don't have a cure but I'd like to use it normally and see what happens, and then use it with the ZoomFocus Init command being sent every 24 hours and see what happens then. Any ideas what the part code for the block cam is ? I've got £10 beer money for you Trade Access/CCTV Member
electrocam Posted November 10, 2004 Author Posted November 10, 2004 Is a tenner not enough, are drinks dearer up there ? How much you want for it ? ! -Dave Trade Access/CCTV Member
BUSTER Posted November 11, 2004 Posted November 11, 2004 We are keeping it for a spare Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
electrocam Posted November 11, 2004 Author Posted November 11, 2004 No probs mate, thanks! Trade Access/CCTV Member
Guest timbean Posted February 21, 2005 Posted February 21, 2005 No probs mate, thanks! 31034[/snapback] hows the 2050 problem just new member have a garage load of kit will look see if i have a module ......
electrocam Posted February 25, 2005 Author Posted February 25, 2005 Cool if you stumble upon a surplus block cam, I'm still after one, fairly cheaply though, thanks Trade Access/CCTV Member
