Irizola screwdrivers, knipex for big snips, pieregoni for precision snips and milwaulkee for powertools.
Elliot lucas pliers from my apprecticeship still, got them secondhand 20 years ago and they are still silky smooth with no play or binding in the hinge.
On 18/07/2018 at 23:52, bm99 said:
Sooo people, thought id find out what cutters and screwdrivers everyone on here uses
Currently got the 160mm bahco's and they;ve been really good, might swap to the 180 but also heard good things about knipex
Screwdivers wise - cant beat the ratchet with the standard terminal and some others. If need be might get the Wera kraftforms just to be a bit different
Just wondering op , do you have everyone's postcode ? And upto speed in van security ?
Wera, wiha, some ck flat heads I rarely use (the heads seem to shear of the others so only flat heads left  so don't buy them anymore) even some Irwin bits
Bosch drill bits I don't mind eauber or however it's spelt for 2/3mm metal bits but never Schneider Christ our place bought some in nearly lost my hand when the bits snap during use
don't worry Al, he's seen your work.
He knows you only have a claw hammer in your van :)
